Home » Topics » Main Forum » PIPER MODELS » PA-24 » cargo door lock
cargo door lock
Posted In: PA-24
    Doug Linville on September 7, 2021 at 1:14 pm #20933
    Thanks. I saw that as a possibility. With your suggestion, that’s what I’ll do.
    Doug
    STEVE on September 7, 2021 at 11:39 am #20932
    Hi Doug,
    I removed my original baggage door lock to install a “Medeco” door lock set from http://www.aircraftsecurity.com.
    I can’t recall exactly what I did.
    As I remember I was tried to slide a thin wrench to back off the nut securing the lock barrel in from where the finger exited the door assy. I reasoned that if I could loosen the lockset enough I would be able to remove the finger.
    That didn’t work so I had to cut a hole in the sheet metal of the inner structure of the door to gain access to the lockset.
    I also needed more access to install the Medeco lockset.
    I hope this helps,
    Doug Linville on September 4, 2021 at 7:11 am #20927
    can someone provide instructions how to remove the cargo door lock/latch on the 1961 PA-24?
