Home » Topics » Main Forum » PIPER MODELS » PA-32 » Electric Trim Switch
    Peter Hecht on November 24, 2015 at 6:40 am #17940
    You too.
    Anonymous on November 23, 2015 at 5:01 pm #17939
    Hi Pete,
    I just received the envelope you sent me via postal mail. It wasn’t necessary but thanks very much. I’m just glad I could help you! Happy holidays,
    Anonymous on November 13, 2015 at 2:13 pm #17934
    Hi Pete,
    I worried about its safe arrival, I’m glad that it made it. I’m hoping that it solves your problem.
    Peter Hecht on November 13, 2015 at 11:26 am #17933
    got it–thanks–looks good- will put in soon and advise.
    Pete
    Anonymous on November 11, 2015 at 7:50 pm #17932
    Hi, I mailed you the trim switch about a week ago. Have you received it yet? Did it work for you?
    Anonymous on November 2, 2015 at 2:12 pm #17919
    Hi Peter,
    There is no charge for the switch and I’ll get it out to you this week. Thanks for being a member of PFA, it means a lot to me.
    Peter Hecht on November 2, 2015 at 10:44 am #17918
    The switch is bad. We did the check you suggested and the trim system is operational when the switch is bypassed. I would like to purchase your extra switch. Please advise the cost with shipping and send your address and I will et a check out. My address is Peter Hecht, 9170 Isles Cay Drive, Delray Beach, FL 33446.
    Thanks again.
    Pete
    Anonymous on October 30, 2015 at 3:23 pm #17912
    Hi Pete,
    And don’t forget, if the switch is bad, I have a switch for you.
    Peter Hecht on October 30, 2015 at 12:54 pm #17911
    Good advice. Will do and I will advise. Thanks much
    Anonymous on October 29, 2015 at 4:13 pm #17910
    Hi, I think you’re talking about a push-button trim enable-disable switch under the left yoke on the lower panel, correct? Put a jumper across it and see if your trim works, or put an ohm-meter across it with the trim circuit breaker pulled out and see if it goes to zero ohms with the trim switch in. Also, I’m going to the airport tomorrow and I think I have an unused trim switch in my hangar. If I do you can have it.
    Keep me informed,
Viewing 10 posts - 1 through 10 (of 11 total)
