Hey Mark –
Thanks for the update. Hmmmm is right. Working too fast perhaps?
Hey Mark –
HOT OFF THE PRESSES, FOLKS! Mechanic had a few minutes to look at the problem. He went straight to the alternator and found the field terminal to be loose. He installed that overhauled engine 23 hours ago.
Now, he is incredibly meticulous but he has two apprentices working with him. Hmm….
Thanx Alex. The video was very informative. LED position/strobe lights recently installed but the problem occurs when they are not in use. Not much load to reduce but I turned off autopilot and #2 nav com with no effect. In videos Mike Bush claims problems with Hartzell alternators. I am not yet able to determine anything about my current alternator.
I’m missing lotsa good flying in this beautiful fall weather! 🤷♂️
Thanx, as always, for your input, Kristin. Ours is a gear-driven alternator buried deep behind the engine. Mechanic hasn’t examined it yet. Today it went offline for 19 minutes shortly into a flight and returned to charging after 19 minutes.
Hard to troubleshoot over the internet, but first thing I would check is the output cable connections and then field wire that likely run together or close together. One good way to test the field circuit, other than visually, is to turn on the master switch and see if the shaft of the alternator, at the center of the pulley, is strongly magnetized. If it is, then wiggle the field wires. If the magnetization waivers, you have an issue with the field wiring. Obviously this could be a problem in the regulator or the alternator, but this is the cheapest and easiest check, so a good place to start.
Mark, any signs of what’s happening prior to the alternator going offline? Does the voltage ramp up or waver? Adding / removing load do anything? Could very well be a regulator or OV relay.
These are hard to troubleshoot over a computer, but here is a link that is all about aircraft alternator circuits. About the 34 minute mark is troubleshooting info:
Piper Turbo Arrow 3 SN 28R-7703041
20 SMOH
Several times during local flight the alternator has stopped charging for no apparent reason then minutes later resumes charging. The annunciator light first lights then the JPI low battery flashes as the battery discharges.
This first happened 2 days ago while flying a practice approach and to get fuel. Checked circuit breakers; couldn’t figure anything else to do. Decided to just go back to home airport. While climbing out and turning around, it began charging again. Hmmm…..I decided to get fuel while I was there. Later, on my way home it stopped charging again and a few minutes later began charging again. Two days later on a test flight, 5 minutes after takeoff it stopped charging. I cycled the alternator switch with no effect. I started a timer and just flew around the area. After 15 minutes it began charging again for another 30 minutes, at which time it stopped again and I retuned to my airport. True to form, it resumed charging before I landed. The alternator switch was cycled after each failure.
Piper Service manual offers little specific help. The alternator field circuit has in series an overvoltage relay and a voltage regulator.
Any qualified help and recommendations toward a diagnosis of this problem will be appreciated. I have talked with one mechanic very familiar with Cherokees but not my regular mechanic. It’s Friday night!
