Adventure Pilot Releases iFly EFB 14 with Satellite Imagery, Enhanced Charts, and Performance Upgrades
Home » Topics » Main Forum » ADs & ALERTS » ALERT! Garmin GFC 500 un-commanded automatic pitch trim runaway
Posted In: ADs & ALERTS
    Jen D on November 23, 2022 at 4:41 am #21690
    Garmin
    1200 E. 151st Street
    Olathe, KS 66062
    913-397-8200
    TO: Owners/Operators of GFC 500 with optional pitch trim installed
    DATE: November 21, 2022
    SUBJECT: Automatic Pitch Trim
    [b]
    PRODUCTS AFFECTED[/b]
    All certified Garmin GFC 500 Autopilots with an optional GSA 28 pitch trim servo including those installed by STC SA01866WI are affected.
    NOTE
    GFC Autopilots installed in Cirrus SR20/22 aircraft using STC SA01866WI are not affected.
    NOTE
    For Experimental and Light Sport installations refer to Garmin Service Bulletin 22112.
    ISSUE
    An un-commanded automatic pitch trim runaway may occur when the autopilot is first engaged.
    WARNING
    Engagement of the autopilot with this condition may result in an un-commanded deviation
    from the intended or desired flight path
    ACTION
    Before further flight, one of the following actions must be completed:
    Disable the GFC 500 Autopilot by pulling the AUTOPILOT circuit breaker and placard the Autopilot ‘Inoperative.’
    OR
    Contact a Garmin dealer to disable the pitch trim as directed in Garmin STC SA01866WI Service Bulletin 22110.
    [b]
    RESOLUTION[/b]
    This issue will be corrected in a future software update (expected in Q4 of 2022).
    • GarminGFC500APAlert.pdf
