Pete, I had the exact same issue with R main gear on my Lance – turns out the restrictor was put in the wrong place at some point in time. Had it moved and no more whoomp!
Wrt adjustments on the emergency gear system, if it’s anything like the Lance (which I’m pretty sure it is), it can definitely be adjusted. I believe it has to be done in flight so you adjust for the correct airspeeds so you need to go fly with a mechanic who is knowledgeable on this system. There should be a procedure in the maintenance manual. On the Lance, the mechanism is located under center row seats alongside the main spar.
As Steve says, there is a separate air pressure mast for the emergency gear system, and that drives ram air into one side of a “bellows” mechanism, and static air into the other side. When the difference in air pressure is high, the mechanical linkage attached to the bellows keeps the hydraulic shunt valve closed and maintains hydraulic pressure in the high pressure lines (keeping the gear up). When the pressure difference drops below a certain threshold, the spring force over-powers the bellows and the shunt valve opens, shorting the high pressure hydraulic line to the low pressure return line, allowing the gear to drop by gravity.
There is a tension screw on the spring mechanism that can be adjusted with a screwdriver, which changes the airspeed at which the shunt valve opens. There is another adjustment for when it closes. Both airspeed values should be indicated in the maintenance manual.
Hope this is helpful.
