Hi!
I’m partners in a ’79 PA-28-236 and we’ve been having off and on nosewheel shimmies on landing, predominantly when applying brakes. It seems worst at lower speeds in the landing roll; for example, if you apply brakes at higher speeds it’s initially OK, then it starts to shimmy and if you keep the brakes applied, it gets progressively worse so brakes are released and then reapplied with some shimmy, the process is repeated, and then the shimmy disappears altogether below maybe 15kts or so.
Various techniques have been experimented with by varying back pressure on the column to take weight off the nose. No success.
Again, it only seems to happen when applying brakes and it seems worse in the right pedal. We have checked all tires for round, played with nosewheel tire pressure (up to max and then down in increments), checked rotors (pads are quite new) and everything seems fine; we even rotated the main wheel assemblies to the opposite sides, but the shimmy hasn’t changed.
About 9 years ago the damper was replaced with the Parker Hannifin model (very expensive) and it seemed to do the trick until a few years ago when the shimmy started up again. We rebuilt the damper about 50hrs ago and checked all linkages for play, etc. and that seemed to help for a bit, but it’s baaack LOL
I’ve read elsewhere online to check rudder cable tension, we’ve not done this yet. We are considering a second rebuild of the damper as a new one is several thousands of dollars!
Any ideas? Thanks!
