AD 2026-22-13, Lycoming Engines Piston Pin Replacement & Oil Inspection
LYCOMING – Mandatory Service Bulletin
Always Be Learning
Home Ā» Topics Ā» Main Forum Ā» EGT cylinder 2 rising Pa28-236
    Kent Dellenbusch on November 16, 2026 at 8:23 pm #29013
    In reply to Kristin Winter (#29010)
    Thanks Kristin.
    Kristin Winter on November 16, 2026 at 8:02 pm #29010
    Carbureted engines sometimes will vary a bit with throttle setting, etc.Ā  I would check to see if your intake tube is loose and the gasket and coupler seem to be in good condition.Ā  You may need some A&P help with that.
    Sylvain St-Georges on November 15, 2026 at 3:24 am #28992
    Hi, I have a question. On my Dakota PA28-236 1979, the EGT on cylinder no 2 vary time to time from 1460 to 1560 . Any information about the possible problem. ThanksĀ  Sylvain
Ā kent@aviationgroupltd.com
Contact:Ā 626-844-0125
All rights reserved. PIPER FLYER ASSOCIATION. Ā© 2004-2026 All Rights Reserved
