McFarlane Aviation Acquires Airglas
Home » Topics » Main Forum » PIPER MODELS » PA-28 » Engine shutdown
Engine shutdown
    Jerome Heller on May 16, 2016 at 4:57 am #18189
    Shut off fuel including primer and still runs.. Mechanic says need new carburetor. Curre nt one has 7500+ hours on it. 1977 Warrior.
    Jen D on May 5, 2016 at 10:09 am #18183
    This is from Steve Ells:
    “…the engine/prop combo is going to continue to rotate for a few seconds; there’s nothing except the compression stroke of the cylinders to stop the rotating mass (crankshaft, prop and other parts) after the fuel has been cut off.”
    -Steve
    If there are other symptoms of a problem, please let us know and we can research further.
    Jerome Heller on May 2, 2016 at 8:14 am #18180
    After shutting down, engine and prop continue to windmill for a few seconds. Is this a problem?
