Thanks, Steve!
Instrument/Nav light rheostat
Hi Chris;
Piper used the Inst lts/nav lights rheostat to control both circuits. As i understand it, when the switch is rotated all the way to the stop in a counter clockwise direction, the nav lights are off and the instrument lights are off.
Immediately after rotating the switch off the counter clockwise stop, the nav lights circuit is energized. Further rotation in a clock wise direction controls the intensity of the instrument lights.
This set up is common to a great many Piper airplanes.
I took that switch out of my Comanche and installed a discrete switch for my nav lights and a MaxDim instrument light controller for my instrument lights. Check out the specs on the Max Dim light controller at: https://www.maxpulsemaxdim.com/.
If your switch/rheostat is beyond cleaning up, I’m pretty sure you will be able to find one at one of the major salvage yards. FWIW, the MaxDim unit, although expensive is modern technology and as such, will use much less power than the rheostat based system.Hi all,
So, the annual is complete on the 1960 Aztec I’m looking at “adopting”. On of the issues is that there is no power to the nav lights at the wings. There is a rheostat marked Navigation/Instrument lights that turns but has no detent. Is that normal? First rheostat switch I’ve ever seen so I have no idea. Need to take the seats out in order to lie down and get behind the panel to check electrical continuity/presence but didn’t get a chance yet. Other forums state that this is a common failure …..any thoughts??Thanks, Chris
