Home » Topics » Main Forum » MAINTENANCE » Left pedal not braking
    STEVE on February 2, 2024 at 11:46 am #22373
    Hello Jose;
    I’m grateful for your feedback.
    It feels good to know that I helped you.
    José Reyes-Hernández on February 1, 2024 at 5:36 pm #22370
    Hello Steve, just to let you know the mechanics followed your recomendation and has worked. Thanks Again for your advice.
    José Reyes-Hernández on January 17, 2024 at 5:48 pm #22345
    Thanks for the advise Aaron. The mechanics will be working tomorrow on this issue. Will update you.
    José Reyes-Hernández on January 17, 2024 at 5:45 pm #22344
    Thanks Steve. Tomorrow the mechanics will be working on the brakes. Will keep you posted.
    STEVE on January 10, 2024 at 7:47 am #22338
    Hi Aaron,
    Thanks for adding this tip for brake bleeding Pipers.
    Every little bit of information helps helps.
    Aaron Kahn on January 10, 2024 at 4:00 am #22337
    Yes, bleed the brakes.  I use a technique where I take a long length of clear vinyl hose to connect between the bleeder valve and the small can holding the fluid.  This allows me to keep pumping the brakes until I don’t see any further air bubbles in the line.  The other issue that I had was a broken o-ring in one of the master cylinders which would allow air into the master every time it was actuated.  Took the master out and had all the o-rings replaced, and it was good as new.  Also, check all the lines under the panel to see if you see any fluid.  They can get old, crack, and let air into the system.
    Aaron
    STEVE on January 8, 2024 at 12:44 pm #22333
    Hi Jose;
    You are not alone. The Cherokee brake system is difficult to fully bleed. An owner promised me the following method will completely bleed the brakes.
    “Cherokee 6 owner in a hangar nearby checked to see how we were doing. He suggested the following method to bleed the brakes:
    He had one of us sit in the left seat holding the brakes down and the other sit in the right seat pumping the brakes while also pumping the handbrake. We did this individually on both the left and right main wheel B valves. It worked! Two days later we repeated this procedure just to ensure that we had indeed removed all the air and that the brakes are firm and holding.
    Please let me know if this works.
    José Reyes-Hernández on January 5, 2024 at 10:09 am #22331
    Hello, happy new year!
    I have a PA-28-161 and have been having trouble with the left brake pedal. It does not have any pressure. After trial and error two mechanics suggested to replace the entire brake assembly and service all master cylinders. After the replacement with two brand new brake assembly and maintenance to the master cylinders, i had no problems for about a month. Again I have no pressure on the left pedal and there are no leaks. I can’t even now remember how many times we,ve bled the system thinking there might be air to no avail.
    However, if I pump the hand brake it will regain pressure for a few minutes and loose it again. We’ve been through the service manual twice to no help in this issue.
    I would appreciate any ideas on cause and/or solution you may give me.
    Best Regards to you all;
    José
