Home » Topics » Main Forum » MAINTENANCE » Missing cowling heat shield
    STEVE on January 3, 2025 at 10:05 am #22935
    Hi Al,
    The holiday season caused a delay in getting this information from the Piper factory support staff.
    The insulating blanket material can be purchased under part number 189-446. I typed “Piper 189-446″ into Google, and it showed sources.
    You’ll have to determine how much you need by measuring what area was covered on the inner surface of your upper cowling.
    The blanket was affixed using a very common high strength adhesive known in hangars around the world as 1300L. It’s a 3M product
    Aircraft Spruce and Specialty (www.aircraftspruce.com) sells a couple of heat shield products that, from user reports seem to be able to protect fiberglass cowling parts, such as HEAT BARRIER ADHESIVE BACKED – 12″ X 12”  part number 08-00630. But the products in the Aircraft Spruce catalog are not the material Piper applied to your cowling.
    Sorry it took so long to get you an answer.
    Happy Flying.
    Aircraft Spruce also sells 1300L; price is $72/quart.
    STEVE on December 18, 2024 at 10:34 am #22914
    Hi Al,
    I need your airplane serial number to narrow down my search.
    Al Lipper on December 18, 2024 at 7:12 am #22912
    I have a 1984 PA32R-301 Saratoga (non-turbo).  The upper cowling looks like it once had some kind of heat shield material stuck to it (though I can’t be sure).
    Should I put some kind of heat shield material on it?  If so, what would I use and does it get stuck on?
    I’d be grateful if Steve Ells or anyone with some knowledge here could reply.
    Thanks.
    Al
