Service Bulletin 1457, FS 156 Lower Skin Rivet Inspection
Service Bulletin 1452, Tee-Bar Sprocket Inspection
Home » Topics » Main Forum » Welcome Mat » Narco AT 150 TSO transponder w/Mode C
    Jen D on June 15, 2013 at 9:50 am #17220
    Hi Tom,
    Check with Texas State Technical College http://www.terraavionics.com and Soloy http://www.soloy.com/capabilities/faa+approved+repair+station/default.aspx
    Both handle some transponder inspection and repair, I don’t know if your specific model will be covered. Both are Piper Flyer supporters.
    Tom Thompson on June 14, 2013 at 12:27 pm #17219
    My 1969 PA 200R Arrow is having intermittent transponder signals, causing problems for ATC. I am told problem is tubes are bad, and will only get worse. Narco is no longer in business, Garmin is not in replacement business.
    Any suggestions or other remedies?
