Hi Robert;
Congratulations on getting a new-to-you Saratoga SP.
I am the owner of a 180 Comanche and I have been able to get all the parts I have needed over the past 15 years. Of course, the supply chain, shortages and increased cost of everything including shipping has extended lead times on many items.
A few years ago I did need new engine control assemblies. I was able to get new ones made to the specifications of the old ones by McFarlane Aviation in Kansas. McFarlane has FAA approval to manufacture a wide variety of commonly needed Piper and Cessna parts.
I finally decided to give up on my old 50 amp generator-I’m an A & P and it’s my personal airplane so I had the time and tools to repair and refurbish it as needed–and replace it with a FAA approved 70 amp 12 volt alternator and regulator from Plane Power.
I suggest you take a little time to go the the Piper aircraft Technical Publications page (https://www.piper.com/technical-publications/) and select your airplane in the drop down menu on the left-then you’ll have a list of the known problems (and factory fixes) with your airplane.
Let me know if you need more help.
New Member PA32 at KCTJ
Hello! I’m Robert Newsome and I recently purchased a 1988 Piper Saratoga SP that is based at KCTJ which is 40 west of Atlanta, GA. Look forward to getting to know you all and sharing experiences. I have owned a Piper Cherokee 180 and also a Piper Comanche 250…both really great planes! It has been 10 years since I’ve owned the 250 but I have stayed current although I haven’t flown as much as I would like.
Quick question for you all…what are some of the more critical components, parts, items that you focus on soon after purchase / first annual inspection? I have gone through the logs and of course done a pre-buy inspection. However, the plane is 34 years old and I want to make sure anything that is near the end of useful life is inspected and replaced. For example, throttle/mixture cables? No issues with them but I have no clue when they have been replaced last. Another example is that I found out the alternator is 20 years old and I do plane on replacing it at annual.
My plane has 5500 hours on frame and 250 hours on engine that was overhauled June 2020.Robert
