I acquired 2 “large”, M size tanks. Have refilled my oxygen successfully. Not a difficult process. Easily accomplished in my hangar.
ON BOARD oxygen refilling???
Joe,
I believe portable tanks can also be refilled with the same “equipment”. My understanding is the filling tanks need higher pressure than your portable tank. I am acquiring 2 larger tanks to provide enough pressure for in built in tank to be refilled.Kent-
what is ON BOARD O2 refilling? Can you refill portable tanks this way too. Can you send me a link to look at this? ThanksJoe
Hello Scott,
Thanks for the info. I have the O2D2 unit from Mt High. Found Aviation Oxygen transfillers for Scott systems. Less expensive than Mt HighGuestHi Kent,
Try the following companies and let me know if you get a workable answer.
http://www.mhoxygen.com (this is probably the best choice), http://www.aerox.com, http://www.skyox.com, http://www.aircraftspruce.com.
N344TBJust purchased a 2001 Toga II TC. Need to refill the O2 tank. Does anyone have a site for ordering the proper equipment to allow “self filling”? Thanks
