I think you’re looking for the minimum thickness permitted. Can you find a Cleveland part number on the wheel? That will help me determine the disc that’s installed.
Once I determine which disc is installed I can give you the minimum thickness dimension.
PA-22 brake drum in service final dimension
Hello Oren.
I had asked Vern at Parker Hannifin your question and his reply is:“The ID of the drum is 5.4175 diameter. More importantly is the distance between the top of the drum that fits into the wheel half to the height that the ring should rest is 1.189.”
Hope this helps.
KentHello
I’m new to the site and was looking for information on the final dimension on the Cleveland Drum brake out of service limit thickness.Thanks
Oren
