Brendan;
I need to back track a little. Do the other screws that hold the landing light bezel in place look like a 6-32 or 8-32 threaded screw? Or do they look like a pointed coarse threaded sheet metal screw?
Since the landing light bezel is not a structural part, it’s very likely that it was held in place with a sheet metal type screw and is screwed into clip nut
Can you see the nut on the back? with a mirror? and flashlight?
If you can, does it look like it’s threaded?
If it looks threaded, then someone in the past probably tried to hold the bezel with a sheet metal screw, thereby screwing up the threads. If that’s the case, you’ll need to tap the nut before installing a new screw.
Let me know what you find.
