If you search “entry door” it will come up in search. We are in the process of adding all our archive of articles from 2004 to present – but it takes some time! 🙂
Piper Flyer Mag, 9/20/13: Dick Russ Door Article
Hi James,
Here’s the link to the article. Please let me know if you need anything else.Jen
Proper Entry Procedure: Fitting and Adjusting the Piper PA-28 Entry Door article by Dick Russ.
My PA-34 Seneca door is identical to a PA-28 door and the procedure outlined in the article is A+ really works. At the articles (and Mr. Russ’) suggestion, I’ve replaced the old eyebolts and clevis pins on the front and back doors and installed AN960 washers (one thick washer) under each front eyebolt. I had already replaced the door seals three times to no avail. I’ve been frustrated over the last ten years of ownership at never being able to get the doors to seal. Having replaced the old eyebolts, clevis pins and installed washers on the front door my airplane is now so quiet that my wife didn’t wear a headset on a 3 hour trip to and from KMCD, Mackinac Island, Michigan. I’m really pleased as the constant noise and draft annoyance is now gone.
Thanks Jen and your team for getting this article published. And thanks Mr. Russ for figuring this stuff out for me.
Best regards,
