Home » Topics » Main Forum » PIPER MODELS » PA-32 » Saratoga intermittent alternator warning light
    Andrew Campbell on January 17, 2023 at 2:11 pm #21776
    I’m flying tomorrow, so I shall recycle the breaker several times before flight and after any failure. Sod’s law says it won’t happen at all tomorrow.
    Charles W Pickering Jr on January 17, 2023 at 12:31 pm #21775
    The alternator breaker. There were times that I would get the annunciation very early in the flight (soon after startup) but most of the time it was after flying for a little while and then it would happen repeatedly even after cycling the alternator switch on and off.
    STEVE on January 17, 2023 at 11:10 am #21772
    Hi Chuck,
    Thanks for weighing in with this troubleshooting tip. Many of our airplanes are still flying with circuit breakers that are pretty long in the tooth, as they say.
    Andrew Campbell on January 17, 2023 at 1:51 am #21771
    Hi Charles
    Thank you for taking the time to write. The problem is not resolved as yet. I too replaced the alternator when it first occurred around two years ago, however, the indication still exists. I can get it from startup and intermittently at any point during the flight. The output remains good throughout and the standby alt never kicks in. Which cct breaker was causing the issue?
    Andy
    Charles W Pickering Jr on January 16, 2023 at 2:37 pm #21770
    Not sure if you’ve been able to resolve your problem yet, but I had a very similar issue happen about a year ago. After my maintenance guys replaced the alternator (which I was sure was OK but they insisted it wasn’t) and 2 voltage regulators (one which was identical to the VR in the plane and the second being one recommended in an old AD), the problem ended up being a $20 circuit breaker. It was heating up and failing over and over again. My issue would happen about 1 1/2 hours into a flight and then intermittently from then on.
    Chuck
    Andrew Campbell on November 24, 2022 at 5:19 am #21692
    Steve – I’ve spoken to B&C and they more or less told me what i already knew. However, I’ve only tested it below 2000rpm which, maybe the key to why there’s no indicated output. It’s the main warning light which is irritating.
    STEVE on November 14, 2022 at 10:28 am #21677
    Hi Andrew;
    It doesn’t appear as though a standby alternator was a factory option for your Saratoga.
    However, there is a STC approved standby alternator from B and C (www.bandc.com).
    I suggest you look through your aircraft records to see if there’s any information about the installation of a B and C back up alternator system.
    You may need to remove the cowling to get a look at the alternator (it mounts on the back of the engine on the accessory section. If the B & C alternator is installed, it has a maximum capacity of 20 amps, so there are some caveats that need to be observed if you ever need to use it.
    If it’s a B and C system, I suggest you contact B and C for an installation diagram so you and your mechanic can determine if it has been installed correctly.
    It may be that when you switch your main alternator off, you are drawing too many amps for the B and C to appear to be on line.
    Let me know what you find,
    Andrew Campbell on November 12, 2022 at 7:41 am #21676
    Hi Steve and thank you so much for taking the time out to answer this query. I have a 2006 PA-32R #3257422 with an Avidyne EX5000 cockpit. Another question, whilst i have your attention; it has a standby alternator, there are no checks for this in the POH and the only indication that it’s ‘working’ is the amber warning light comes on if you turn the main alternator off. However, at the same time i will get a Low BUS voltage warning, and there appears to be no output indicating on the MFD. I have only ever tried this at run up, never in flight, so i don’t know whether it needs to be run at higher RPM to produce a sufficient output?
    Any feedback will be much appreciated.
    best regards
    Andy
    STEVE on November 3, 2022 at 8:26 am #21655
    Hi Andrew;
    From your description, it seems as though the fault is in the annunciating system for the alternator.
    The obvious conclusion is that a connection is loose between the alternator annunciator wiring and where the power is picked up off the battery solenoid.
    The fact that you’re not seeing any problem with the main alternator power output is a good sign.
    FWIW, the diode bridge in the alternator (there are three) convert the alternator current produced by the alternator into direct current (DC) that can be used in our small airplane system. If you had a bad diode the DC would not be as smooth as before. This is pretty easy to detect as it produces a high pitched whine that increases in pitch at higher RPM. It’s easy to hear in your headset.
    The fact the behavior of the system changed after the alternator was changed seems to indicate that the intermittent connection could be in the connection between the stator of the alternator and the alternator “out’ switch.
    At this point it’s only a guess; I’ll need the serial number of your airplane to dive deeper into the wiring diagrams.
    Andrew Campbell on October 26, 2022 at 11:23 pm #21653
    Around two years ago, my 2006 32R 301T started displaying an intermittent alternator warning light, coming on normally during start up. Resetting the alternator occasionally cured the indication, sometimes it would simply go out before departure. Although the light was on, the output voltage and charge was normal – 28.6v dc on the BUS and at no time does the standby alternator kick in.
    I thought it might be a rectifier starting to fail, which I believe is on the alternator, so I had my shop change the alternator. This changed the symptoms, the light would come on for perhaps 20 secs on start up but then extinguish. Now the light occasionally comes on on startup, may go out or will stay on through the flight. Still the output is normal even with the warning light on.
    Any ideas please?
    Andy
Viewing 10 posts - 1 through 10 (of 10 total)
