Home » Topics » Main Forum » PIPER MODELS » PA-34 » Seneca Annual Inspection Prices
    Kristin Winter on January 19, 2016 at 2:25 pm #17990
    Getting someone who really knows the aircraft, doesn’t just claim to, is a good thing in the long run. However, that first annual can be a bit of a doozy when you are playing catch up. Now days, I would warn someone who brought me an aircraft to annual in which I knew very well that this first annual would be expensive. However, these days I only do a few owner-assisted annuals. They still aren’t cheap, but the owner knows exactly what is being found and why it is a problem.
    Anonymous on July 8, 2014 at 2:27 pm #17439
    Hi David,
    My email address is scotts@techenterprises.net. Send me an email with your email address and I’ll scan my invoice and send it to you.
    Scott
    DAVID MCKENNA on July 8, 2014 at 5:48 am #17438
    Scott,
    Can you post the items repaired/replaced on your annual inspection. My annual is being done this month, and your experience would be ‘invaluable’.
    David
    Seneca III
    C-FJMM
    Anonymous on July 5, 2014 at 6:15 pm #17429
    Well folks, Pat Berry had it right on the nose with his “mates rates” comments back a few months. I’ve been meaning to get back to this topic with the results of my own most-recent annual inspection. To recap, I moved to a new airport because my last annual took five months and I was frustrated. Skipping to the latest annual, Pat, you were on the nose! Apparently I wasn’t getting sufficient maintenance as my latest annual inspection invoice was six pages long and included countless items that appear to have been neglected over the years. I was worried that I was changing A&P’s for not a good reason. However, if you would look at the list of parts replaced (and I looked at every single replaced part for wear) you would conclude that this latest annual cured a lot of ills.
    Your comments show a lot of wisdom, which can best be summed up by “you get what you pay for”. It turns out that my decision to change mechanics was a good one. Perhaps I should have met you a few years ago!
    Anonymous on February 20, 2014 at 9:19 am #17359
    Hi Pat,
    I hadn’t heard the term “mate’s rates” but that term seems more than appropriate. (I did learn something new today!). My A&P had done ten of these annuals for me and the plane is in good shape. Last year I moved to a new airport where hangar and fuel were much less expensive and my plane is currently getting an annual at the new airports shop. I expect it to be done in a week or so and I’ll be able to report on what they found and how much it cost. Stay tuned.
    Scott
    Patric Barry on February 1, 2014 at 9:46 am #17351
    We call that “Mate’s Rates”. It’s great if he really knows the Seneca and can do a good job.
    For example – I’m a Comanche specialist – I know every inch of the Comanche and I am used to the ADs and repetitive maintenance. But put me in a Bonanza and I have to start from scratch, so if the IA that you are using really knows the make and type he can do a good job.
    A lot of an annual can be done by the owner – opening up the aircraft, changing oil, cleaning plugs. The time it takes to remove seats, carpet floor panels is better done by the owner because it a) saves time, and b) let’s the owner see for himself the condition of the aircraft. There’s nothing better when you are over the Rockies knowing that the plane you are flying has integrity.
    Anonymous on February 1, 2014 at 8:36 am #17348
    Hi and your question is right on the money, if you’ll pardon the pun. The $900 bill was by a retired A&P who did this for a hobby and he was a personal friend…
    Hope that helps,
    Scott
    Patric Barry on January 31, 2014 at 3:28 pm #17344
    If your inspections were $900 and the repairs $500 to $2000 I suspect that you were getting insufficient maintenance.
    The log book inspection takes a lot of time and if it is on AdLog it saves a lot of time. Each page is signed off for compliance and I can do an AD review in a morning where if I have to go back in those little logs books it can take an entire day.
    If you open up the plane, yes, the inspection and log book inspection can be done in two days. However, you have repetitive ADs which must be done and they vary based on time and flight time.
    Alternatively, become an A&P and do your own work, and then you save all of that money.
    Michael Leighton on January 29, 2014 at 7:40 am #17343
    The book says its about 30 hours to inspect a PA 34 – 200T – multiply that times the hourly shop rate. Here in Palm Beach it ranges from $75 to $110 per hour. I dont know whart kind of annual inspection you can get for $900 bucks. I have never gone thru an annual and didnt have to fix something. These plane are 35 + years old- you are going to be fixing stuff all the time.
    KETIH MOES on January 25, 2014 at 7:48 pm #17341
    Hi Scott,
    I’ve owned my 75 Seneca II for 12 years. I have the annual done at a suburban airport and the base inspection cost is $2400.00. On top of that add for oil, oil and air filters etc. I usually have one or two minor things to fix and I try to replace one or two items that have been on the aircraft so some time such as hoses. Final bill runs $3500 to $4000 or so.
    Keith Moes
Viewing 10 posts - 1 through 10 (of 11 total)
