Kevin,
Welcome to the forum. What is your mission? And how do the finances look? And of course what do you want? There are a lot of “PA-32s” you can consider from the old Cherokee 6-260 right up to Turbo Saratoga. I happen to like the PA-32 series but obviously the PA-46 is a whole level up from them. I don’t know if you are considering the Matrix (unpressurized) or if you think you need the pressurization. If so then the pressurized PA-46 is the only choice here. The Malibu will put you in a different operating environment than the Cherokee 6/Saratoga as it can go to much higher altitudes. Of course you don’t have to fly at the higher Flight Levels but then why buy a pressurized airplane?
