Home » Topics » Main Forum » PIPER MODELS » PA-24 » tachometer issue
tachometer issue
Posted In: PA-24
    STEVE on July 9, 2020 at 8:05 am #20028
    No, not really, I had a Horizon electric tach in my Comanche before I went full engine monitor. It worked perfectly and fit in the same hole as the mechanical tach. It appears the company may have retired since the product is no longer listed on Aircraft Spruce and Specialty. But there is a used one on eBay: type Horizon P-1000 into the eBay search window. Asking $250.
    There are a number of approved replacements. A couple include the Electronics International has its R-1 and the J.P. Instruments Slim Line tach.
    If you haven’t yet decided, you can get a TruTrak II from Aircraft Spruce. This is a portable battery powered unit that is not connected to any aircraft systems. Velcro it to the dash, point it at the prop (it can adjust for 2,3,4, and 5 bladed props) and get a true reading of your engine rpm.
    Doug Linville on July 8, 2020 at 1:38 pm #20027
    my airplane is a 1961 PA-24 250. I am having occasional issue with the tachometer, it oscillates at times and isn’t accurate. I removed, cleaned, and lubed the cable.
    I am considering replacing the original with an electric. What are your thoughts? I want the new instrument to fit in the instrument panel where the old one is. Is this a difficult upgrade?
    Doug
