Thanks. This looks about right to me.
uAvionix Skylight green LED nav light dim
Hi Arthur.
Maybe, you might find a replacement LED bulb here.
https://navstrobelighting.com/?product_cat=ba15swcs-10w-1156Kent
After a close inspection of the right nav light, I find that it is not a UAvonitx skylight. It looks like a standard nav light that uses a LED replacement for the original incandescent bulb.
I can tell you that should you replace it with the SkySensor you have the green light and ADSB In! It’s pretty each to get field approval / 337 since the light portion is the same as the skybeacon.
The Piper Cherokee 180 I operate has a uAvionix Skylight green nav light. The light is dim and flickers. Does this indicate that the whole unit must be replaced$ $600 is a lot of money for a nav light.
