Home » Topics » Main Forum » MAINTENANCE » Uneven tire wear on Arrow main gear
    STEVE on December 27, 2023 at 9:08 am #22329
    Hi Mark,
    I found the following MLG alignment procedure in the Arrow III service manual.
    So to me it’s unclear why he told you that the alignment can’t be done.
    I’ve attached the actual pages from the service manual.
    Mark on December 26, 2023 at 2:49 pm #22326
    My Turbo Arrow 3  PA28R-201T suffers from uneven wear on the main gear tires. The outer groove on one side wears away before the others causing rejection at annual inspection. My mechanic says that there is no adjustment to correct this problem. I maintain proper pressure.He says that this is common on the Cherokee line.
    Does anyone know of a solution for this? It’s not a rapid condition but it sure would be nice to get more landings from those tires.
