SkyHound is the only self-contained portable ADS-B traffic and weather unit in existence.
Home » Topics » Main Forum » PIPER MODELS » PA-28 » Prop is shot – PA-24 (not PA-28)
    STEVE on November 18, 2021 at 9:53 am #21061
    Hi Michael;
    The consensus between the owner and a local A & P is that the prop will need to have AD 97-18-02R1 completed before it’s again airworthy. This AD is due every 5 years or 600 hours time in service.
    If you’re interested, the owner will listen to bids.
    Where is the airplane located?
    The spinner back plate and spinner are included.
    STEVE on November 17, 2021 at 9:31 am #21051
    I have attached photos of the prop my friend has for sale.
    STEVE on November 15, 2021 at 8:34 am #21038
    Hi Michael,
    I know of a used 2 blade prop that was removed from a Comanche 250. It’s in very good shape and was overhauled very recently. I’ve seen it and it appears to be in very good condition. It is located in Paso Robles, CA (KPRB). I will find out more today and post more information.
    I don’t believe the owner wants more than $6K for everything, but I’ll check today to see if my memory is correct.
    He installed a MT three bladed propeller ($$$)
    Frank on November 13, 2021 at 7:16 pm #21035
    Hi Michael –
    My vote would be to call John at Diamond Aire in Kalispell. They are primarily a twin shop but have a ton of experience with Piper overhauls and maintenance, and it’s possible he would have a useful opinion…
    Good luck!
    -Frank.
    MICHAEL CUMMINS on October 1, 2021 at 4:35 pm #20961
    Comanche 250 has been sitting for several years and in process of getting AD’s and annual. Prop has been determined to be too costly to overhaul. Recommendation is to either get a new McCauley 3 blade ($16k) or buy a used prop and overhaul current governor ($10-11k). A different recommendation is to get a high performance 2 blade Hartzell from Johnston Aviation ($14k) that requires changing the counter weights (extra labor – $2k). Any advice would be appreciated.
