SkyHound is the only self-contained portable ADS-B traffic and weather unit in existence.
Home » Topics » Main Forum » PIPER MODELS » PA-34 » Piper Flyer Mag, 9/20/13: Dick Russ Door Article
    Jen D on December 27, 2018 at 9:45 am #18902
    If you search “entry door” it will come up in search. We are in the process of adding all our archive of articles from 2004 to present – but it takes some time! 🙂
    james on December 27, 2018 at 5:44 am #18898
    I am not sure I replied to you but if not thanks for the digging into the archives for me. BTW is it something I am able to find by searching myself on this site?
    Jen D on December 13, 2018 at 4:12 pm #18882
    Hi James,
    Here’s the link to the article. Please let me know if you need anything else.
    https://www.piperflyer.org/maintenance-technical/item/1216-proper-entry-procedure-fitting-adjusting-the-piper-pa-28-entry-door.html
    james on December 11, 2018 at 2:14 pm #18880
    thank you
    Jen D on December 11, 2018 at 1:14 pm #18879
    Will find it and post it.
    james on December 8, 2018 at 10:41 am #18878
    I am new to Piper Flyer and cannot find a copy of the magazine. How do I find it. I have the same issue and was going to create a post until I saw this thread.
    Jen D on September 15, 2013 at 6:07 pm #17262
    Great to hear, Scott. We’re so lucky to have so many knowledgeable folks contributing to the magazine. Glad you found this article helpful!
    PFA Staff 4 on September 14, 2013 at 5:48 pm #17261
    Proper Entry Procedure: Fitting and Adjusting the Piper PA-28 Entry Door article by Dick Russ.
    My PA-34 Seneca door is identical to a PA-28 door and the procedure outlined in the article is A+ really works. At the articles (and Mr. Russ’) suggestion, I’ve replaced the old eyebolts and clevis pins on the front and back doors and installed AN960 washers (one thick washer) under each front eyebolt. I had already replaced the door seals three times to no avail. I’ve been frustrated over the last ten years of ownership at never being able to get the doors to seal. Having replaced the old eyebolts, clevis pins and installed washers on the front door my airplane is now so quiet that my wife didn’t wear a headset on a 3 hour trip to and from KMCD, Mackinac Island, Michigan. I’m really pleased as the constant noise and draft annoyance is now gone.
    Thanks Jen and your team for getting this article published. And thanks Mr. Russ for figuring this stuff out for me.
    Best regards,
