Here’s what Steve Ells has to say:
Hi Ian;
You need to find the best air conditioner service expert in town and get him to: 1) find the leak—I can email you the procedure but a good AC service person should know how to find leaks; 2) seal the leak; 3) evacuate the system to clean it out—this is done with a vacuum pump; 4) install a new receiver-dehydrator unit (Piper part number 456 615) since it will lose the dehydrating power if exposed to outside air; 5) add the proper amount of oil to the compressor; 6) service the system with refrigerant.
Since you already know the location of one of the leaks (above or forward of the pedals) you’re can start by looking at the hoses in that area to check for deterioration, wear, abrasion etc. I don’t have the exact parts book for your Arrow II but the Arrow III parts book I have seems to show flexible hoses installed between the rigid hoses. It may be that all you need to do is change the flexible hoses.
There’s nothing that’s abnormal about this system; it’s the same as any other small A C system.
One thing we have to deal with here is the fact that the original refrigerant was R-12. The Environmental Protection Agency (EPA) here is the States ruled that R-12 Freon was toxic and after 1995 new cars had to use R-134a. This created problems when older cars needed servicing because the market for R-12 lessened and in accordance with the law of supply and demand the price started climbing.
It’s possible to convert a R-12 system to use R-134 but modifications have to be made. If you can still get R-12 use it.
If you can’t get R-12 then there are less efficient refrigerants on the market—you’ll have to talk to the best AC guy in town to find out which one to use.
I’ve found that many airframe and powerplant (A & P) technicians here are not familiar with servicing AC systems. That’s the reason I suggest you find an experienced auto or truck AC mechanic. BUT you’ll need to be sure your A&P is willing to sign off on the work.
