Home » Topics » Main Forum » MAINTENANCE » Carb Heat Shroud
Carb Heat Shroud
    STEVE on May 9, 2021 at 10:41 am #20651
    My suggestion is to get some small pieces of stainless steel to use as shims to tighten up the shroud around the exhaust pipes.
    I doubt that high temp silicone would last very long.
    Without seeing a picture of which part is loose and where it’s loose, it’s difficult to know what to suggest.
    Can you send a photo?
    Aaron Kahn on May 3, 2021 at 7:47 am #20639
    I have a ’67 PA-28-140. The carb heat shroud has come slightly loose. It has a slight rattle, and I cannot tighten it any further. There are no cracks (yet) as far as I can observe. Was wondering if some high-temp silicone calk could be used to fill in the small gap around where the shroud clamps onto the exhaust stack header?
    In general, this part seems to be a general headache for all of the other folks on the airport with similar aircraft.
