1998 Piper Saratoga II TC
Digital Display Monitoring Panel (DDMP) Failure / Error code.
Today, an interesting thing happened as I was about to leave on a trip.
I turned on master switch, The DDMP went through its normal startup and function test. Instead of everything passing the test, the CAT failed ( whatever CAT is)…
Then the following message appeared on the front of the screen:
DDMP OP SYS FAIL SHUTDOWN CODE 1.
Has anyone ever seen this before or had any experience with it?
This is the little display that displays digitally all of the information that is also displayed on the row of steam gauges below it. I believe all Saratogas from 1995 – 2003 had these. Also the 1997-2003 Seneca V also had these.
John
