Home » Topics » Main Forum » MAINTENANCE » Faceplate for King KAS 297B Altitude pre-select
    Jen D on December 18, 2017 at 5:35 pm #18514
    Here’s the entire unit on eBay. https://www.ebay.com/p/King-Kas-297b-Altitude-Preselect/1923648869
    Are you looking for the metal plate that surrounds the display or the LED digital display itself?
    DAVID MCKENNA on December 18, 2017 at 7:26 am #18513
    Thanks Kent and Jen. I did order the lens, but what is needed is the LED ‘faceplate’ that shows the numbers, not the lens.
    David
    Jen D on September 12, 2017 at 9:36 am #18447
    Hi David,
    I found this listing on eBay: [url=http://www.ebay.com.sg/itm/Display-lens-KAS-297B-altitude-pre-select-preselect-lenses-aftermarket-USA-/262903445550?hash=item3d3644382e:g:Aq8AAOSwzgBY0Rh6]Display Lens[/url] s-l64.jpg s-l64.jpg
    STEVE on September 11, 2017 at 10:26 am #18445
    Hi David;
    Did you get the faceplate solution that worked?? Of course if you hand flew your Seneca once in a while the autopilot selector faceplate wouldn’t be worn out.
    Kent Dellenbusch on August 22, 2017 at 9:44 am #18435
    David,
    Reach out to Steve McKinny at Air Capitol Dial. He might be able to help you.
    https://www.aircapitoldial.com
    1-877-269-2483
    Kent Dellenbusch on August 22, 2017 at 9:28 am #18434
    David, is the faceplate worn or broken?
    Kent Dellenbusch on August 22, 2017 at 9:16 am #18433
    Looking into it for you. 🙂
    DAVID MCKENNA on August 22, 2017 at 8:46 am #18431
    Does anyone know where the above can be purchased and for how much? Thank you.
