Home » Topics » Main Forum » PIPER MODELS » PA-28 » Fuel Tank Removal for Spar corrosion insp
    STEVEN STOCKMEIER on August 25, 2016 at 3:57 pm #18261
    I removed the wing tanks and found no corrosion. I treated the spar and sprayed corrosion X inside of the wings since I had access. I found the RH fuel sending unit was leaking. I replaced it with an overhauled unit. Replaced all vent and fuel hoses and reinstalled the fuel tanks. Only had to drill one screw out. Oh, also replaced one vent which I broke, costly little things. All and all it was pretty painless.
    STEVEN STOCKMEIER on June 16, 2016 at 12:52 pm #18221
    Does the PA28-140 have enough room to slide the fuel tank out and disconnect the fuel lines? There is no inspection panel to access them.
    Anonymous on January 25, 2016 at 7:04 pm #18017
    Attached is a procedure from PFA resident A&P, Steve Ells. I hope this helps! Let me know if you have any further questions.
    Take care,
    • PiperWingTankInsp.pdf
    Anonymous on January 24, 2016 at 4:28 pm #18009
    Hi, I’ll find out from out resident guru, Steve Ells. Please stand by.
    Lydell L. Newby II on January 24, 2016 at 2:00 pm #18007
    Not really. You slide the tank forward just enough to get to the clamp and the sender connection. Really the easiest part of the task.
    STEVEN STOCKMEIER on January 24, 2016 at 1:49 pm #18006
    I have left hand drill bits. The good news is that the screws have been replaced and aren’t rusted. Can you disconnect the fuel line and gauge wires before you remove the tank or as you remove it? I can’t find a reference for the the tank removal in the maintenance manual.
    Lydell L. Newby II on January 24, 2016 at 1:12 pm #18003
    Oh and the last and best thing for the job. A good set of left handed drill bits for the stubborn ones. They are life savers
    Lydell L. Newby II on January 14, 2016 at 10:57 am #17976
    Usually takes a couple hours per side. Including reprinting the spar. And a 140 with a 180hp? Wow. Must be an STC’d install. What a hot rod.
    STEVEN STOCKMEIER on December 3, 2015 at 6:08 pm #17944
    Thanks for the info, good news is that the screws had been replaced a few years ago and look good. Why the tank screws were replaced I don’t know. There is no sign off for the spar corrosion SB. I’ll let you know how it goes. Steve
    Anonymous on December 3, 2015 at 5:41 pm #17943
    I’m sorry that you have to remove your fuel tanks for the corrosion inspection. I just repaired two areas of corrosion on my 1977 Seneca 2 this last summer and it was expensive and time consuming. It turned out okay with the two areas in question repaired with new parts and it’s as good as new now. Back to your issue. While our airplanes are very similar in the design of fuel tanks I had a couple of compounding issues, one of which might affect you. The first issue, which does not affect you is that I had to remove my de-ice boots. That’s a hugely expensive proposition and I’m glad you don’t have to deal with it. The second area was the removal of fuel tank screws that hadn’t been removed since 1977. I spent about a month, off and on, removing those screws. I had to purchase rusted screw removal kits from Sears to get them out. Ultimately, my mechanic got the last few out that were hugely rusted in place. Once out, the tanks came out very easily for inspection. Finally, when you go to put the tanks back in, make sure that you use only new screws. Note that the back row screws are different than the side screws. Make sure that you get only approved screws as these are structural items. And make sure that you either grease the new screws or use bee’s wax (my mechanic used the latter) so they come out easier next time. Good luck with your project and let us know how it turns out.
Viewing 10 posts - 1 through 10 (of 11 total)
