Home » Topics » Main Forum » PIPER MODELS » PA-28 » HEATER PA-28 151
HEATER PA-28 151
    STEVE on December 28, 2017 at 9:19 am #18527
    If the flapper is working correctly and the defroster is working, there must be a blockage in the ducting aft of the control. I suggest you get a strong flashlight and an inspection mirror to look inside the ducting to see of a creature decided to move in and build a nest.
    If your mechanic has a borescope that will help view the inside of the heat ducting.
    Please take pictures and let me know what you find.
    Gregory Brown on December 22, 2017 at 9:21 am #18519
    The heater on my warrior does not seem to be working. The defrost works bur when i slide the heater lever, no heat comes out. checked the flapper valve and it works, also made sure the floor vents are open. Any Ideas
