Home » Topics » Main Forum » PIPER MODELS » PA-32 » Leaking rear baggage door
    STEVE on April 18, 2020 at 11:27 am #19856
    Thank you for passing that on. I need a new door seal; your information is helpful
    Wendell Johnson on April 14, 2020 at 1:37 pm #19845
    Air Mod recommends Brown Aircraft Supply.
    STEVE on March 11, 2020 at 9:46 am #19783
    Hi Steven,
    Yours is not an uncommon problem. On the plus side, rain is water and doesn’t pose an immediate threat to the airframe. But airplanes shouldn’t leak. I believe the best door seals can be bought from Brown aircraft supply (www.brownaircraft.com) in Florida. It has been in business for a long time–a salesman there may know which seal works best for your PA 32R-301.
    Many years ago, i worked on DC-3s and I seem to remember seeing a L-shaped part attached to the fuselage above the door to divert rain water off the top of the airplane away from the door opening.
    In my opinion, a simple L shaped part of 2024-T3 aluminum riveted in position above the door opening would do a lot to solve this problem. It won’t have to be big; perhaps an eighth inch for the flange and an eighth inch for the “dam” part. If I were doing it I’d slant it slightly with the forward end being 5 degrees higher than the aft end. The fabrication and installation of this rain gutter would not need any FAA approval–in my mind this constitutes a minor alteration.
    Of course, this option depends on how your mechanic sees it. He may not be comfortable with this idea.
    Please let me know if you find a viable solution.
    STEVEN GUCCINI on March 8, 2020 at 8:31 pm #19782
    I own a 1995 PA 32 301R. I was recently in South Carolina and was parked for a week and we had heavy rain for 2 days. When I left a couple days later the rear baggage area was wet. I gather from some research that this is a common problem. There seem to be lots of door seals on the market, with reviews running from mediocre to terrible. Any suggestions on the best fix? Thanks, Steve Guccini
