Home » Topics » Main Forum » PIPER MODELS » PA-28 » PA28-140 Ιntense – Fine Vibration on the floor
    Charalampos Avgousti on April 23, 2024 at 12:04 am #22492
    Dear Steve, Hello. Finally the cause for the vibration seems to be some screws not so tight on the engine cowling. After I tightened them up, the problem disappeared.
    Thank you very much for your advices.
    Charalampos
    Charalampos Avgousti on April 18, 2024 at 12:02 am #22479
    Dear Steve, Thank you very much. I will check everything you mentioned and I will fly it again. I will let you know. Thank you again.
    STEVE on April 17, 2024 at 1:24 pm #22477
    Hi Charalampos,
    I suggest that you look closely to determine if there’s a small piece of weather stripping, or anti abrasion tape esp. where the cowling or other sheet metal might rub or vibrate against an adjacent part. There isn’t anything central to the engine or propeller that will create that type of vibration.
    I would also check to see if any of the inspection panels in the floor are loose, or if any of the screws aren’t tightened up.
    Although the location is wrong to create a floor vibration, check for any looseness in the door or door trim pieces.
    Get down under the airplane, clean the belly and look for loose fasteners.
    There has been a warning to inspect the welded tubes that form the left and right rudder pedals. Check for cracks at the welds. Perhaps there’s a crack in one of the welds that’s creating the vibration.
    Check those possibilities and get back to me.
    Charalampos Avgousti on April 17, 2024 at 4:52 am #22476
    Hi fellow pilots.  On my last flight with my PA28-140 I felt an intense-fine vibration on the floor, near the centre axis of the plane. I felt that on several power settings.
    We checked everything and that is not coming from prop or engine, nor the rudder.
    Have anybody had anything similar?  Any ideas?
