A Cherokee 140 is pretty underpowered for high-and-hot operations, especially if you start to load it up with people and/or fuel. The best-case scenario at 2150 pounds at a density altitude of zero is about 675 feet per minute, and it only gets more anemic from there. At 5,000′ DA, you’re looking at 475 fpm, and at 10,000′ DA, just 280 fpm. They’re good little airplanes, but they have some significant limitations in the low-horsepower models.
I based a Cherokee 180 out of the high desert for several years (home field elevation of 4164′) and flew it routinely with DAs significantly higher than that. Even with the extra horsepower in the 180 model, I had to pick and choose my days if I wanted to go places where takeoff and climb performance were important. Weight made a huge difference as well. Lightly loaded (two people, 20 gal fuel), I could get in and out of a lot of the nearby “backcountry” strips. Max gross? Nope, not going to try it.
In addition to what Steve has said about density altitude, there are other factors that can limit an aircraft’s climb performance.
A few years back, I did a trip to Sisters, Oregon (6K5). When I landed, it was very bumpy and windy out of the west (this is important in a minute), and getting hot. I spent the afternoon at a BBQ and departed at around 6pm; the hottest time of the day. The OAT was around 95F, field elevation 3,200 feel msl. Density altitude was just over 6,500 feet at departure.
For the airplane I was flying, that was no big deal. It was just two of us in the plane and it had plenty of power for that operation (a 180hp Cessna 172). Takeoff and initial climb were fine, albeit a bit slower than at sea level. At around 5,000 feet msl, I started feeling like we were struggling to climb. At around 6,000, there wasn’t any climb performance left. It just WOULD NOT climb. That was a big problem, as I wanted to be at at least 8,500 for a westbound crossing of the Cascades (terrain at around 7,000 on that route).
I checked my engine gauges and all seemed fine, but the airplane just… wouldn’t climb. A quick look at the OAT confirmed that the density altitude was high; around 10,000′ by my math, but not so high that I’d run out of climb performance. By the book, that aircraft had a service ceiling of around 17,000′, Bizarre.
I considered going back to the airport. First, though, I flew toward an open area of hay fields (rare in this area; most is forest). I found a bit of a thermal there, and was able to spiral-climb up to 8,500 with relative ease.
When I turned toward the Cascade crest, it became obvious what had happened with my initial attempts to climb. There was a significant (40-ish knot) west wind at altitude. The Sisters airport is on the lee side of the mountains, and the air was spilling over the top and down the slope into the valley, creating a large area of downdraft (over the forested areas near the airport) that I couldn’t outclimb.
I ended up climbing up to 10,500 to cross the crest with ample room below me, as the high winds suggested that I might encounter turbulence as I got closer to the mountains. That didn’t happen, and it was a smooth flight from there back to my home base.
A very strange experience to find that I couldn’t get above 6,000′ in one spot, and then a few miles away, having plenty of climb performance.
