Home » Topics » Main Forum » PIPER MODELS » PA-28 » Relocating oil cooler on PA28-140
    Marc Vaillancourt on April 4, 2018 at 3:45 pm #18615
    Meighan, I’m looking for the 337 now and will send it when i find it.
    Lydell L. Newby II on April 4, 2018 at 2:55 pm #18614
    I got one from him a while back also. I was going to do that also. But in the meantime I sold my 140 and bought a 28R. So that leads me to this. I have a complete set of engine baffles in serviceable condition that I picked up to do the retrofit. If anyone is interested, I might be able to be talked out of them at a reasonable price.
    MEIGHAN K on April 4, 2018 at 1:50 pm #18612
    Thank you very much Jen!
    I’ll be on the lookout.
    Meighan
    Jen D on April 4, 2018 at 12:54 pm #18611
    Hi Meighan,
    I’ve emailed Marc and hopefully he’ll jump online and answer.
    MEIGHAN K on April 4, 2018 at 11:51 am #18610
    I have not received anything yet. Would surely appreciate a copy of the 337.
    Thank You
    Meighan K. Chisholm Sr
    pa22plane@yahoo.com
    MEIGHAN K on April 4, 2018 at 7:38 am #18607
    Would it be possible for me to get a copy of the approved FAA form 337 and any attachments?
    This would be to modify my PA28-140 (Don’t let my e-mail address confuse as it is a carry over from my previously owned Tri-Pacer).
    Your Assistance would be Greatly Appreciated!
    Meighan K. Chisholm Sr.
    pa22plane@yahoo.com
    Marc Vaillancourt on July 17, 2017 at 2:32 pm #18414
    All the parts are listed on the 337. As far as the sketch/diagram, I used the Piper Warrior (PA28-161) parts diagram as listed in the parts book. The oil cooler installation is the same in both the Maintenance Manuals. I included the copies of both the 140 and 161 parts illustrations as well as the installation instructions for the oil cooler when I submitted it to the FAA.
    I believe I sent you the back side of 337 before, did you get it? Let me know. You can email me at vaillankm@gmail.com.
    Lydell L. Newby II on July 15, 2017 at 4:58 am #18406
    Thanks for the information. Just a quick question or two. Did you list all the parts on a 337 and include a sketch or diagram of the new placement before you actually went to FSDO to start the approval process? And if so, can you share the parts list with me as I am going to go out to Wentworth (they on my home field) and look for all the necessary arts minus the lines. I sure appreciate it as I have often thought about the oil leak problem myself. The plane starts its annual end of august so it would be great timing if I can get it done. Plus with the new AD for oil lines again the timing is perfect.
    Thanks so much.
    Marc Vaillancourt on June 29, 2017 at 4:23 pm #18405
    Here’s what i sent to the FSDO. I had new type D oil lines made up at acft spruce…you could also order the oil lines for a PA28-161 and they would work. All other parts (baffles and oil cooler mount) were Piper parts that are from a Warrior (PA28-161). I used my original oil cooler with 90 degree fittings and it worked OK.
    Let me know how it works for you.
    Marc
    Lydell L. Newby II on June 27, 2017 at 6:16 pm #18404
    I meant to say PowerFlow. Dang Smart Phone.
Viewing 10 posts - 1 through 10 (of 13 total)
