Home » Topics » Main Forum » PIPER MODELS » PA-28 » Relocating oil cooler on PA28-140
    Lydell L. Newby II on June 27, 2017 at 4:12 pm #18403
    I also installed a powerful and would appreciate any information you might want to share with regard to relocation, line location and mostly rerouted air cooling ducts.
    I’m at dhrmotorsports@msn.com. I am also an A&P and work with numerous IA’s.
    Thank much.
    Lydell
    Marc Vaillancourt on April 23, 2017 at 8:20 am #18366
    Finally got the Field Approval to move the oil cooler from the front to the rear of the engine.
    Marc Vaillancourt on September 4, 2016 at 5:34 pm #18270
    PA28-140 originally has the exhaust on the firewall. I installed a PowerFlow exhaust and it is now located at the front of the engine. I’m concerned about an oil fire if the oil cooler leaks, so I want to install at the rear of the engine. This would put the oil cooler in the same location that the PA28-161 currently has. I would be using all Piper parts for the relocation.
    Does anyone know of an STC or Field Approval for this mod? I am an A&P with IA and the local FSDO would like to know if this mod has been previously accomplished before they would give me a field approval. I consider this a Safety modification (I don’t care to find out what would happen if the oil cooler were to leak and have an oil fire inflight, I would like to avoid this situation).
Viewing 3 posts - 11 through 13 (of 13 total)
← 1 2
