Mountain High Receives FAA NORSEE Approval for EDS-305X Series O2D2 Oxygen Systems
Service Bulletin 1156D, Nose Gear Drag Link Bolt
Nearly 35,000 Girls, 200 Events: International Girls in Aviation Day Returns September 19
Home » Topics » Main Forum » PIPER MODELS » PA-34 » Seneca Hot start advice
    Jacqueline Shipe on May 20, 2018 at 11:56 am #18658
    Hi Seth,
    Whenever I have to start almost any fuel injected model after the engine is warm or hot, I typically leave the boost pump off, mixture full lean and throttle full forward or cracked an inch. I crank the engine until it begins to start and then reverse the the throttle and mixture (pull the throttle back to idle, enrichen the mixture). I try to be fairly quick with reducing the throttle so the engine doesn’t rev way up once it does start. Its a lot easier to accomplish with two people, one person can crank the starter and control the throttle and the person in the right seat can help with the pushing the mixture control forward. This technique works well on a Cherokee Six. On a Navajo I’ve left the throttle cracked about an inch, boost pump off, mixture lean and slowly advanced the mixture as I’ve cranked, and it worked pretty well. I haven’t flown the Seneca but I bet it would work on it too.
    Hope that helps,
    Jackie
    Seth Kornblum on May 20, 2018 at 8:44 am #18657
    Hello all,
    New to this group, as my wife and I just acquired our Seneca II just a few months ago.
    Wondering if anybody can give nay suggestions/techniques for starting these engines when hot.
    The manual doesn’t seem to offer much helpful guidance.
    Thanks in advance for any suggestions,
    Seth
