Home » Topics » Main Forum » PIPER MODELS » PA-28 » Winterization plate for oil cooler.
    Jen D on November 14, 2017 at 12:38 pm #18493
    I asked Wayne Thomas of Pacific Oil Cooler – here’s his take:
    “Hello Jen,
    I suppose that mounting the winterization plate would work just about the same, even if mounted on the rear of the oil cooler. You’re still accomplishing the intended result which is to prevent airflow through the core of the oil cooler.
    I have not seen one attached in that location – but then, we never get to see an actual aircraft. Just the oil coolers.
    Thank you very much!”
    I’m not familiar with the AVCON modification – can you tell us more about it?
    Sincerely,
    Wayne Thomas
    Sr. Sales and Technical Advisor
    Pacific Oil Cooler Service, Inc.
    STEVE on November 13, 2017 at 12:20 pm #18492
    Hi Scott; I’ve never seen on installed on the back of a cooler in my 40 years of aero maintenance. I suppose someone would start a business manufacturing “winter fronts” as they’re called for older Cessnas and Pipers, because the original ones are few and far between.
    When I worked in Alaska, most owners cut a piece of aluminum to cover most of the oil cooler, and then used duct tape to attach it to the front to the cooler. As far as I know, no one ever got busted for it, but that was Alaska.
    The chances of there even being a winterization plate for your modified airplane are pretty lean.
    If I were you, I would fabricate a piece of aluminum to cover a portion of the cooler. You want to cover enough to get the oil temperature up to 180 degrees F, if possible.
    STEVEN STOCKMEIER on November 11, 2017 at 6:02 am #18491
    I have a 1973 PA28-140 with an AVCON O-360-A4M STC. My oil cooler is mounted behind the rear left cylinder. It would be very difficult to put a winterization plate on the front of the oil cooler but easy to install one on the rear of it.Has anyone ever seen it installed on the rear of the cooler? I would think it would be the same result. Thanks for any info.
