Hi Brendan;
I apologize for not getting back to you right away.
Can you tell me more about why you think the aileron repair was done wrong?
For instance,
Can you sight down the trailing edge of the aileron and see a twist?
Are you seeing a mis match between where the inner end of the aileron matches the outer end of the flap?
Or where the outer end of the aileron marries up to the wing tip?
Do you see an obvious problem with the repaired aileron when you compare it to the other aileron?
Can you send a picture of what looks wrong?
