The Best Bang-For-Your-Buck Piper Modification: Vortex Generators
Questions & Answers: Lifting a Cherokee Without Fuel Tanks, Glareshield Replacement, Backcountry Tri-Pacer
Home » Topics » Main Forum » PIPER MODELS » PA-31 » Correct Drain Valve operation
Posted In: PA-31
    STEVE on March 17, 2024 at 8:33 am #22428
    Hi Helio;
    I believe that valve is to ensure that any fuel in the induction system drains out when the engine is shut down. If I’m correct, it is a one way check valve.
    The test for a one way check valve is:
    Apply pressure to the tube end–no restriction in airflow
    Apply pressure to the fitting (threaded end)–no airflow.
    Helio Mario Pimentel on March 15, 2024 at 11:32 am #22426
    Can anyone give us a comment about the drain valve  P/N 41287-00?as:- is there any test we can do to check that it works perfectly?
    – we bought a new one, but we suspect it is not blocking the flow correctly when we blow through our mouth.  Thanks a lot,
    Helio Mario – Brasil
