We took the Apache out after having to miss flying a few days (work and windy days). I had two things in mind. One, to test the door some more before we close it up. It did great and I think we have finally gotten past the door issues so now we will put the interior back into it.
Second, I wanted to do some speed checks as we have done a lot of work on the plane (especially the engines) and initially I thought it was a little down on speed. The air at the lower altitudes was a bit bumpy. We went to 8500′ on the last check to avoid bumps and to stay out of clouds. Each run was made to the West and then to the East. We then averaged the GPS ground speeds. Quick and dirty but it should give me a good idea of what the plane can do. This is with a fairly light weight plane, mains 3/4 full, no tip fuel and just two pax, no luggage. One of my “hangar buddies” flew with me and wrote everything down and that was a nice help. Notice it is all in MPH!
Results:
3500′ – 24″ x 2400 rpm, 151.5 mph
5500′ – 24″ x 2400 rpm, 156.5 mph
8500′ – 21″ x 2400 rpm, 155 mph
8500′ – 21″ x 2100 rpm, 152.5 mph
Obviously we aren’t accurate enough to be measuring in half mile an hour increments but we divided by two and that’s what we got! At any rate I am pretty happy with this as an initial set of numbers to start planning with. I’m really happy with the lower power setting at 8500′ as that should be about 58% power and that is about 15 gph when leaned out. I figure I can plan on around 130 kts (150 mph) pretty much any time at the normal cruising altitudes. I will try to get better figures as I fly more but this was a great start. It looks like the engines are doing pretty well and I’m really happy with the work my mechanic has done.
Pic is of the finished door with interior stripped out. You can see the reinforcements added as well as extra springs to make the latching mechanism work.
