AD 2026-22-13, Lycoming Engines Piston Pin Replacement & Oil Inspection
LYCOMING – Mandatory Service Bulletin
Always Be Learning
Flying an Apache
    Eric Parks on July 27, 2021 at 5:16 pm #20801
    Finally got time with my mechanic buddy to finish the brake caliper fix. We had already changed the tire on the left main but the brake caliper was leaking over time. I could fly the plane but when I came back next time to get it out of the hangar it had a small puddle of brake fluid on the hangar floor. Not properly trained! He had already tried a fix with one set of O-rings but they didn’t seem to work. So he ordered another set from Aircraft Spruce. Turns out these work (at least so far!). Cost for the O-rings: 40 cents!
    Of course my buddy had to buy a new tool for bleeding the brakes. Once he got it set up (first time) he was able to bleed them in 3 pumps. He was totally thrilled with his new tool. I didn’t ask him how much that cost!
    After getting the brakes fixed we had to try them out, of course. First gentle taxiing with lots of brake applications. Then a rejected takeoff. Full power to 60 mph then idle and stand on the brakes. Finally we did a quick pattern. We checked the brakes after each test and all looked good.
    Since you have already seen the plane on the jacks getting the tire and brake work done I took a couple pics as I “put the plane to bed”. Notice the trickle charger for the battery hooked up to the GPU plug. My buddy recently fixed the GPU plug as it was INOP before. So now I can attach my battery trickle charger to it to keep the battery fully charged. It has helped to make a big difference in starting the engines. The props really spin now! We are still planning on adding the Bogert copper starter cables this winter but now the plane is starting well. The copper cables should just be a bonus. GPUplug.JPG GPUplug2.JPG
    Eric Parks on July 12, 2021 at 6:33 pm #20796
    Time for the old girl to get a new shoe! Found a bubble starting on the sidewall of the left main so I bought two new tires (so I would have an extra for the right main when needed). My mechanic replaced the old tire. He is also trying to track down and kill a brake fluid leak that has been tough to end. So the tire is done but the leak chase continues. He got the caliper rebuilt but says he needs a pump to properly bleed the brakes. He’ll get that done while I’m on my next trip. At least now we are being more proactive with the repairs!
    Eric Parks on July 10, 2021 at 3:46 pm #20791
    Since getting the Apache flying I have wanted to test the cruise speed for max cruise. The book says about 6500′ with 75% is going to give the max cruise speed. However, every time I tried to test there were clouds at that level or it was just too bumpy. So yesterday I had the perfect day to check it out. I had a buddy that was a 727 pilot go with me and we went out to check the Apache for best speed. We climbed up and I was beginning to think it wasn’t climbing as fast I would expect. I set up cruise power and thought maybe an engine was running a little rough but nothing seemed wrong. Checking the speed I could see it was not giving me as much as I expected. However I still couldn’t figure out what was wrong. After getting back I did my figures. I had taken speeds on the 4 cardinal headings and came up with an average ground speed of 156.5 mph. While not terrible it was not what I expected and I was pretty deflated. Driving home I was trying to understand what the issue was. I thought that if I was in my Airbus I would have thought the issue was my landing lights extended as they will “rumble” a bit and take a very slight performance hit. I don’t have lights that extend, not even cowl flaps.
    Then I realized what the problem was, the door was causing the drag! When we taxied out I had mentioned to my buddy that the door handle should come up further. He pulled it up but it didn’t go up any more. I made sure the top latch was good and we went. While climbing I saw the top latch had let go so I again pulled it closed and it stayed shut. However, I later understood he had never gotten the main latch closed, just the “click” latch. So the door had been slightly “in trail” and caused the rumble and extra drag. Just a little but that was enough.
    So back out today and I did some more tests on my own. This time I made sure the door was totally shut closed! Climb felt great and with the same test parameters (6500′ @ full throttle-23″ & 2400 rpm) I got 162.5 mph. This was more what I had expected. Then going to 2300 rpm it only dropped to 160.25 mph. I then climbed up and tried 8500′ with full throttle-21″ & 2300 and got an average of 156.75.
    So for now I’m happy with the speed numbers I’m getting. I’ll keep track of what I get at cruise when we go somewhere but for now I will claim a “top speed” of 140 KTAS. Or maybe 160 mph since it sounds faster!
    Of course I have a few things planned for the future that may add a little more speed yet. So maybe I can get to 145 KTAS 😉
    BTW, the book says I should get 175 mph as the top cruise speed. I don’t know if ANY 150 hp Apache (including the test plane!) ever got that speed but mine is never going to! That is why I am doing these speed runs, so I can know what to expect from my antique Apache as it is now.
    Gascolator drains are now fixed and don’t leak any more. Door will shut and latch but we need to fix the lock for the handle. New battery and master relay have made starting the engines a totally new experience! The props are turning twice as fast as they were before. My mechanic said he also tightened up some loose connections. It made all the difference. I still plan on installing the copper Bogert cables this winter. The “new” throttle knobs are great. They look and feel much better!
    No pics of the “speed runs” since they are pretty boring but I am including one of my nosewheel (super exciting!) since I I totally nailed pushing the plane into the hangar and getting the nosewheel into the alignment box. I use a golf cart to push it in and it has been a slow process for me to learn how to control it. nailed_it.JPG
    Eric Parks on July 6, 2021 at 7:13 pm #20786
    Along with fixing the electrical issues my mechanic was able to make a very much wanted upgrade.. Aztec throttle, prop & mixture knobs. The old original knobs were orange with pilot sweat and oil and were small and slick to hold. The new knobs are much easier to use and of course are color coded and have different shapes. A fairly easy fix but one of my favorite upgrades!
    I was also able to try out my new USB ports. I had my Garmin portable GPS Aera 660 and my GDL-50 both plugged in and they stayed fully charged all day and worked great. Another small upgrade!
    We averaged about 174 mph going west bound at 8500′ and averaged about 158 coming back at 9500′. So with full throttle at those altitudes and 2300 rpm we averaged 166 mph (144 KTAS) both ways. Yup, had a tailwind going WEST. Not bad for a comfortable cruise setting. I burned 16.4 gallons going over to Franklin (I had them top off the mains just to give them a little business). I find that pretty reasonable for flying a twin!
    I am really enjoying the S-TEC 50 autopilot with the Garmin G5 displays. They both work so well and make flying much easier. One of my purchase requirement for my plane was to have an autopilot with altitude hold and I’m so glad I got that.
    I am going to have to get better headsets! These are cheaper units and just a little too big and clunky. I’m already spoiled by my David Clark Pro headset I use for work so I guess that goes on the “to buy” list. The old headsets will be ok for rear seat pax!
    Eric Parks on July 6, 2021 at 7:02 pm #20782
    More pics from departing Franklin, NC.
    You can see the runway in one picture as I circled in my climb out of the valley. Wife took these pics! FranklinTO3.jpg FranklinTO4.jpg FranklinTO5.jpg
    Eric Parks on July 6, 2021 at 6:58 pm #20778
    I finally got my first “fun” trip done in the Apache. By fun I mean a flight with no other purpose than than to go somewhere for the fun of it.
    OK, true confession time. I had another trip planned, a LONG trip from Charlotte, NC to Dallas, TX. It was 3 legs to get there with about 6.5 hours air time. I had everything planned and filed for IFR. Got out to the airport and put all my bags and stuff in the plane and pulled it out of the hangar. Did my walk around and got in to start the engines and the entire electrical system died! Bummer! Found out I had a bad Master Relay. After 65 years it packed up right then (note: I actually found out later that the relay was made in JAN 1965 so it was “only” 56 years old!). I think all the engine runups with lots of cranking finally did it in. So that was the end of that trip.
    Fast forward two weeks and a new relay (and brand new battery!) later and we have fixed several other electrical gremlins as well. The engines are cranking fast and starting easy. YEAH!
    So Wifey and I flew to a little North Carolina town in the Western NC mountains called Franklin. They have a nice little airport, 1A5 (Macon County). We were treated GREAT. Very nice FBO and we took their courtesy car into town for a little restaurant and shopping time. Flying time was 1.0 going over and 1.1 coming back on the Hobbs meter from Shelby (KEHO). Fun first trip for the wife. She enjoyed her seating position much better in the Apache than she did in the Bonanza we rented a couple years ago. She can see better forward and liked getting in better as well as a more solid ride. So Wifey gives it a thumbs up!
    Only glitch was the outside lock for the door handle didn’t work properly. So we will dive into that. But everything else was great.
    Here are a few pics from the trip. FranklinRamp.jpg FranklinTO1.jpg FranklinTO2.jpg
    Eric Parks on June 14, 2021 at 7:32 pm #20745
    Today was a “work day” on the Apache but now work includes flying! Can you tell I’m excited? We took it out to check out the radios and make sure they are all working. I had not tried an ILS approach or double-checked how that all worked. I’m hoping to do a big (for me) trip next week so this is the final push to get ready in case I need to do IFR. I plan on only “lite IFR” but that can make a huge difference in getting a trip done. I took the plane to 8500′ and had AVL approach control check the altitude reporting. Also checked out the autopilot a bit more and everything is looking good there. All good on that so we went to a local uncontrolled airport (KSPA) to shoot an quick ILS in visual conditions to make sure all that that all worked. It was a complete failure. I couldn’t get the HSI to respond or work.
    We went back to Shelby and started trouble-shooting by finding videos of how to set up the ILS with a Garmin 430 and G5. My friend suddenly gets off the phone and says he checked and the ILS we used at the little airport has been down for months. Oops! Didn’t check any NOTAMS since we were just messing around VFR.
    I quickly checked the status on another ILS at another uncontrolled airport a bit further away (KUZA). It was OK so off we went. It all worked as advertised and I was VERY happy to see it all working so well.
    So at this point I have loaded an ILS approach and flown it and gotten proper indications on both the G5 PFD and HSI. On the way back to home base I let the autopilot track the GPS in NAV and that worked great too.
    We are now planning on what other changes we should make to the panel. Cost is important at this point so I’m looking for good “bang for the buck” but also trying to make the panel more attractive as well as functional. We have some nice things planned that I will post as we get them done.
    Eric Parks on June 5, 2021 at 12:51 pm #20719
    The Apache hadn’t been washed since we got it as we had so much work to do it wasn’t worth it. However, since it was initially in a “shade hangar” the first few months it had more than it’s fair share of dust and bird droppings besides the greasy handprints. And of course bug guts all over the leading edges from recent flying!
    I pulled the plane out of our hangar and used my golf cart tug to take it around to the “wash rack” by the larger hangars. Previous owner had obviously done a nice job of waxing it as the bug guts came off very easily (compared to my expectation). It still took a couple hours to wash, rinse and wipe it down. Suddenly a smaller plane makes more sense! 😛
    The underneath of the engines and behind the exhaust really needed attention but the plane looked great when I was done. Waxing will be another day!
    I’m starting to get the hang of how to use the tug to put the plane back in the hangar. Getting it out easy, getting it back in, not so easy!
    Eric Parks on May 27, 2021 at 7:30 pm #20677
    Finally! We got to fly the Apache with a family member on board 🙂
    My younger daughter wanted to experience flying in the much talked about Apache. Of course for a long time it was being “re-habbed” but finally it got out of rehab long enough to be flown a bit. My daughter can be a little up tight about flying although she is also very interested in it. So I wanted her to just have a quick, short (and hopefully positive!) experience. This was VERY short! Non-stop from Shelby, NC to Spartanburg, SC. A complete 27 nm distance! But she had an old college friend she wanted to meet. So off we went. The drive was way longer than the flight. It went well and she enjoyed the trip and I think she’ll be ready for more soon. Next to get Mom and the older daughter up so they can get used to it before a long trip.
    BTW, daughters can take LOTS of pictures. This is just 3 of 106 pics and videos!
    Eric Parks on May 26, 2021 at 6:20 pm #20673
    Had to go to work and then had a family vacay (courtesy the younger daughter!) to the beach. So finally got a little flying in the Apache. We had the left engine start running rich. Also, had to bleed the right brake down as it was not braking. So wanted to check all that and expand my “comfort zone” with the plane. Everything ran well except battery was low after all the engine runs lately. So I am trying to put a trickle charge on the battery. Filled the mains and put 5 gallons in the tips (I keep them pretty much dry). I was by myself and partial fuel load so fairly light weight.
    Climbed to to 5,500′ with 24×2400 and got 156 mph.
    Then at 9.500 ‘ with full throttle (20.25″) I got:
    2300 rpm – 164
    2200 rpm – 160
    Up at 10,500’ and full throttle (19.5″):
    2500 rpm – 157
    2400 rpm – 155
    2300 rpm – 154
    These are all as good or better than I expected. I am really pleased with how little speed is lost with lower rpm. These are newer Hartzell props and they seem to really work well with the lower cruise revs. I also used the tip tanks for the first time in the air and that went just fine. No issues. It was a little hard to descend and leave my smooth cool air at 10,500 for the bumpy lower air!
    Door interior is now re-installed. Door has been working great.
    GDL-50 has a clip to hold it to the glareshield. This is the first time I used it.
    GPS attaches nicely to the control wheel.
Viewing 10 posts - 381 through 390 (of 393 total)
← 1 2 3 … 38 39 40 →
