Hi William;
Are these “weird off beat” oil leaks originating from the vicinity of the oil pressure switch? As I mentioned in my original post, dye penetrant developer spray, or athlete’s foot spray (the powdery kind) is a great leak location discovery tool.
As to why you look would show up after you’ve shut down, about the only thing that makes sense is that the leak might be coming from the oil pressure gauge–because it has a bourdon tube inside that might be sorta stiff so it may take the tube a few minutes to return to zero. If this is anywhere near logical, the tube does have oil under pressure inside; perhaps a slow return to zero could generate enough pressure to generate a leak.
Unfortunately, that does not explain why there’s no leak during engine operation.
Keep an eye on it, I’ll ask around for tips on this kind of leak
Sorry I don’t have a better answer.
