Home » Topics » Main Forum » PIPER MODELS » PA-28 » Rear Shoulder Harness Options
    STEVE on January 30, 2022 at 9:18 am #21227
    Hi Brendan;
    Thanks for sharing this information.
    I’m sure it will be helpful to other PA 28 owners.
    Brendan O’Rourke on January 28, 2022 at 4:05 pm #21223
    Steve,
    I found Piper service bulletin 896 which lists the kits by model & serial number; this SB confirmed the kit for a PA-28-181 is 763-966. airframe@piper.com did send me the 763-966V installation instruction/drawing which included the component parts list. I was able to acquire most of the components from AVParts in Newman, GA and the mounting hardware from Aircraft Spruce. The only part I need to source yet is a 78557-002 spacer and I think I have some located from an aircraft salvage company.
    I’ll post an update when I install; that’ll be months from now when warmer weather returns to the mid-west and I do my interior upgrade. Thx
    • 763-966.pdf
    • SB_0896_shoulderharness.pdf
    STEVE on January 5, 2022 at 11:25 am #21160
    Brendan,
    Send an email to Piper at airframe@Piper.com.
    If that doesn’t work let me know.
    Brendan O’Rourke on January 5, 2022 at 4:38 am #21157
    Thanks Steve. I’ve had similar results from my searches. I may have to gather up the pieces from part suppliers and do a 337. The parts manual calls out the part numbers but I’d probably need to locate a Piper installation drawing for the install. Any idea how I’d obtain a drawing?
    STEVE on January 3, 2022 at 11:44 am #21154
    Hi Brendan;
    I checked with both Alpha Aviation and BAS-aeromod.com for rear seat 3 point shoulder harness/seat belts. So far, no joy.
    I’ll keep looking,
    Brendan O’Rourke on January 2, 2022 at 2:28 pm #21153
    I have a PA-28-181 that I’d like to install rear passenger shoulder harnesses. Fixed and inertia reel harnesses were an available option for the Archer in 1980. My searches are turning up lots of support suggesting this is an excellent safety upgrade, but the hardware does not seem to be readily available. I’d like to find a set of OEM inertia reel kits #763-966 or an aftermarket STC kit that has the doubler/required mounting for the shoulder harness. I’d prefer to have it an installation similar to original and not one that looks like a glommed on after thought. Thx
